- Jan 13, 2021
- 28
- montana
- Ford Ranger
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
- Total Lift
- stock 4wd
- Tire Size
- 31x10.5R15
Hi folks,
my '90 single cab 4x4 is about 2"+ taller on the right than it is on the left. I understand this is fairly typical for them to "lean", but it looks real bad from the back.
perhaps unrelated, but my steering wheel is also about 30 degrees counter-clockwise when going straight, and the truck pulls slightly right, so a significant alignment job is in order.
I don't plan to have this be a serious off-roading rig, but I live in Montana and sometimes it just happens.
I'm honestly fine with the "stock 4x4 height", and the biggest tires I plan to install would be about 31", 265/70 or 75.
I've been reading up on the lift options, and skyjacker seems like a decent way to go, but if I get their 1.5-2" kit (basically just springs and shocks) will that align decently, or am I actually better off with the 4" system which includes brackets and such?
Also I can't find much info comparing the m8000 nitro to the m8500 black max, any thoughts on this application?
In summary, I don't care to go much taller, I mostly want off-road capable with a decent ride/steering, but I'll go taller if that's just how the geometry works out.
Aside, it seems like there are some "gaps" in the build guide for the particular combination of '90 2.9l 4x4. I'm pretty sure I've got a dana 35 ttb up front, and the rear is an 86(7.5", open 3.73)
Thanks much
Martin
Thanks much
Martin
