Stupid Blinker Question
Seabiscuit
Phoenix, AZ
Why is the blink speed on the instrument panel so different between the left and right arrows?
MAKG
19
California central coast
Bad connection somewhere.
If it were open, one side would stay on forever.
You can try to isolate it with a voltage drop test.
srteach
9
Ranger, F350
4.0L, 7.3 Diesel
The turn signal uses the same blinker for both sides. If one circuit has less power use on it, it will blink faster. A burned out bulb will cause a turn signal circuit to use less power, and blink faster. Check all your bulbs.
martin
26
St Bruno, Quebec
1991
just turn on your hazard flashers and see which bulb is not working.
Seabiscuit
Phoenix, AZ
Is it a difficult task to change both bulbs?
:bling:
Seabiscuit
Phoenix, AZ
Found out rear left brake light and upper brake light needed replacement.
No members online now.
