Strange fuel connection *Solved*
2trux
16
Albuquerque NM
2.9 L
I am trying to remove the fuel line from the regulator on a 90 B2. it is different from any other I have seen. Any idea on how to remove this?
Thanks
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Finger springlock....haaaaate them.
I think it's one of these....I have 3 styles..unless that is the twist one.....
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
It looks like the 4.0 style...the other end of the hose....does it have a hex nut jic style or a spring clip to the frame side?...
2trux
16
Albuquerque NM
2.9 L
The other hose (inlet to fuel rail) has a hex nut type of connection. I have the tools in your first post and they will not go in. the collar at the end of the hose is tight against the regulator outlet. I do not know what the other end of the hose looks like, I'll look tomorrow.
This is what the end of the regulator looks like that the fuel line slips on to. The raised ring is in front of the connector.
Uncle Gump
Token Old Guy
13,478
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I have a set of the Lisle spring lock tools... they might work in this case.
60928
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I've never seen a Ford fuel line connector that this didn’t work on? :dunno:
Also, have you tried cursing at it?
ericbphoto
Overlander in development
16,605
Wellford, SC
6"
I'll disconnect it.
2trux
16
Albuquerque NM
2.9 L
The other end of the hose is a spring clip connection near the power steering.
Uncle Gump
Token Old Guy
13,478
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
They are like a clam shell... open them up and clamp them on. Then they work just like a regular spring lock tool. I think they may be a bit shallower...
Paulos
210
North Carolina
1987 STX
Check out this thread if you're interested in what the tools actually do to separate the fuel lines. The documents in the thread don't go into full detail, but the tool(s) expand the spring so the female fitting can be pulled off of the male fitting. As mentioned in the thread, some lubrication with twisting helps when trying to pull them apart.
2trux
16
Albuquerque NM
2.9 L
I found my answer on another forum. It just needed something pushed into a little slot on the front of the connector and it slid right off. I just bent a 90 on a cotter pin, pushed it into the slot and success.
As you can see there are 2 slots. The high price tool has 2 tabs to push the white ring inside, but the cotter key pushing down one side was successful and cheap.
alwaysFlOoReD
5,102
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Thanks for posting the fix.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Sorry....I should have stated o ring pick for #2 4.0 style. I don't remember seeing those collet style on a 2.9.
At least it came off. They usually get modified up here
