Spring for Dana 35 TTB E/C-Clip Eliminator
Status
Not open for further replies.
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
13
Salem, IN
I wanted to post this info here so that it would be easier for someone to find it in the future.
I used an ECHO spring. It worked perfectly on my Dana 35. Others have used the same spring with the same success.
The ECHO spring part # is 69621655730.
Any lawn shop that carries ECHO will be able to get this for you. You can click the link below to find your nearest Echo dealer.
http://www.echo-usa.com/advantage.asp?transaction=search&template=map_search
The cost from an ECHO dealer is about $5 + tax.
It is hard to get over the splines of the axle shaft, but once you do it works great. The boot will fit over the spring. Get yourself 2 hose clamps to hold the boot on once you put it back as you will destroy the factory retainers getting the boot off.
Here are some pictures of my install.
ForOffRoadDriving
18
HIGHLAND, MICHIGAN
FORD
thanks, you posted that just in time cause me and my little bro are doing his D35 this week and i told him we need to do this mod. im going to head next door to the hardware store (who is an echo dealer) and get one ordered!
martin
26
St Bruno, Quebec
1991
please enlighten, what is echo?
KELLY88
4
Lake Mary/Daytona Beach, FL
4.0, 4.0
Echo is a power tools brand. Mostly lawn tools like lawn mowers, chainsaws, weedwackers, leaf blowers etc.
mjonesjr
Firefighter
13
Salem, IN
There you go.
dusto2
scv ca
2.9
sweet thanks for this one mjones, i just ordered mine off line it was $3 plus $7 shipping, i dont have a echo dealer out here i ordered mine from this place http://www.sepw.com/Default.aspx
entered the part# on there search and it came up,
Sunk
125
Everett, WA
3.5 Eco
Yep, I did this about 2 months ago, and it's been great so far. I called a small engine repair shop which also was an Echo dealer and they had it in stock for about $3.15 I think. The spring was a little difficult to get over the splines of the shaft to begin with, but It can be done.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Another source for a spring is OSH (Orchard Supply Hardware... I think this may be a California-only chain though, not sure). They have a whole endcap on the hardware aisle stocked with various springs.
The spring was a Century Spring # C-812 or C-810 (for some odd reason I can't seem to pull it up on Century's website :icon_confused: )
It was 1.25" I.D., about 2.5" long, with a rate around 20-30 PPI. Like the Echo spring, it took a bit of wrestling to get it over the axle splines, but once over, it fits well inside the boot.
NapalmMan67
DeKalb
FORD
5.4L
Life is short- Play naked!
Where's the shaft collar to hold it in place on the driver side of the shaft, or did you weld it to the shaft on that side?
Or it's just not showing in the pictures?
I used the same spring, it was a bitch to get over the splines for sure. :annoyed:
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
The hose clamp around the boot holds it in place
metalmacguyver
Yeah, I built that.
11
4.0, 7.3
I also used this spring. I think its the best one to use for this modification/article as Echo power equipment is sold nationwide as opposed to the hardware store chain that junkie mentioned. It is also readily available to be purchased as a single unit unlike the springs from century if ordered online.
mjonesjr
Firefighter
13
Salem, IN
I put a bead around my shaft, but the hose clamp would hold it in place like Junkie said.
Status
