Slave cylinder
saleenboy87146
Slave cylinder seems to be on it's last leg. Any special tools needed to remove the trans and slave cylinder ( quick disconnect )?
Any tips on replacing the slave and clutch, removing the trans?
Thanks
Scott
TonkaSTX
You have to drop the transmission, so I recommend ratcheting wrenches and a tranny jack. Will make things much easier. You don't have to worry about the clutch but if you think its time to be replaced might wanna do that while you have the tranny out. You may have to cut your exhaust to get the tranny down, I'm not sure about yours but I had to. After you get the tranny down, there's only 2 bolts hold the slave cylinder onto the input shaft. It slides right off/on. The quick disconnect is a pain in the butt, I'm having problems with it currently, I read somewhere that it's better to just get a new line, without the quik-connect. Mostly it's just common sense. Just bag and tag all bolts you remove
BlackBII
Ranger Custom
Truck of Month
984
UT
Ratcheting wrenches, extensions, swivel sockets, all bolts on tranny/tcase should be 13mm/1/2", Driveshaft bolts will be 12pt 12mm or 12pt 8mm. The slave is bolted on by two 10mm bolts, and can be replaced by just sliding the tranny back, if you have a girlfriend with skinny arms, and is not afraid to get dirty. :D
The tranny crossmember bolts should all be 18mm, you'll most likely need a breaker bar or at least a 1/2 ratchet
I never use a tranny jack, but that's me.
Look here for quick disconnect line. Don't be scared, they're easy.
http://www.therangerstation.com/forums/showthread.php?t=33973&highlight=disconnect
BlackBII
Ranger Custom
Truck of Month
984
UT
