Side mirrors
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Great shots, even with the cobwebs. LOL
Thank you 85_Ranger4x4
BlackBII
Ranger Custom
Truck of Month
983
UT
You can find those mirrors new on eBay. They're aftermarket and made in china of course, though.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,726
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
So which would be better for the mirrors?
jack nuts with a plate or 12g sheet View attachment 56138
or rivet nuts in a brace/bracket about 1/8" x 1" x 6-8"
I suppose I would know better once I find a set of mirrors though.
I would use rivet nuts installed with RTV around the outside to prevent any water intrusion. Ford Ranger doors rust enough from the inside out as it is. The rivet nuts will be stronger.
rebuild83
15
Nebraska
2.5 suspension
235/75 r 15
Ditto on the rivet nuts
Those mirrors use bracket from the inside of the door a nut comes up from the bottom and a screw threw the sheet metal . The brace has treaded nuts on ready to accept the bolts. LMC truck has the mirrors for rangers and f 150s
cschannuth
33
Hermann, MO
306
Expect nothing and I’m like really disappointed
Ok, so is there an interior door brace/bracket for the lower or upper arm on the mirror for support?
There is definitely reinforcement inside the door for that type of mirror.
rebuild83
15
Nebraska
2.5 suspension
235/75 r 15
The brace reinforces the upper and lower mounts of the mirror
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,521
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I'm not so sure riv-nuts fit the bill here. If you do use them they need to be the flush ones. Any stand off in the nut face will push the mirror plate off the door.
I think I was going to use them when I did mine... but went with a plate in the door and tacked nuts to the plate. They actually were solid and didn't move much at all.
19Walt93
4,488
Canaan,NH
351
3"
235/55R16
The plates have a plastic shim/gasket between them and the door panel that would compensate for the height of the crush nuts but I 'd still want a reinforcement inside the door.
Uncle Gump
Token Old Guy
13,521
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
As long as the gasket covers the distance... perfect.
Just something to take into consideration I suppose...
SenorNoob
588
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Anybody bought any new head for that style lately and can speak to the quality? All the reviews I've seen say the new ones are floppy from the factory.
