Elilyon
- Jun 26, 2020
- 0
- California
- Ford Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 4WD
I'm wondering if anyone out there has knowledge on removing the shift cable on a 95 4.0 A/T. Mine is almost broken and won't shift back up into park once in drive. I can shift from P down to reverse down the line, but I have to crawl under the truck and manually put it back into park. Looked and the cable was loose and sitting on the exhaust pipe and melted the heat housing and partially through the cable. The part is obsolete so I'm trying to get a replacement at a Picknpull but can't figure out how to detach the cable from the bracket next to the transmission. It seems fairly straightforward except for getting this bracket off, and I can't find any videos for how to replace the cable on any year Ranger. I'm attaching a picture of the piece I'm trying to get off. Any help is greatly appreciated.
