Safe to Run Engine with Driveshaft Removed?
Basilius
23
USA
Ford Ranger XLT
2.5 (4 Cylinder)
2.5L
I'm doing some work on my truck and the one-piece driveshaft is currently removed from the manual transmission. Is it safe to run the engine with the driveshaft removed, or will it cause problems? I need to put air in my tires and the air compressor connects to the car battery, and the engine needs to be running.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Manual trans ...yup
franklin2
1,758
Virginia
Bronco II
It will most likely throw oil all over the place if the driveshaft slips up inside the trans. I assume the trans has oil in it?
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
Basilius
23
USA
Ford Ranger XLT
2.5 (4 Cylinder)
2.5L
Yes the manual transmission currently has fluid in it, and the (removed) driveshaft slip yoke goes into the transmission.
fastpakr
2,832
Roanoke, VA
If the compressor connects to the battery, why does the engine need to be running?
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
Basilius
23
USA
Ford Ranger XLT
2.5 (4 Cylinder)
2.5L
The air compressor will quickly drain the battery if the engine isn't running.
fastpakr
2,832
Roanoke, VA
How long are you planning on running it? Given that it's probably going to sling oil from the driveshaft slip joint, there's got to be a better option. Can you park another vehicle near the truck?
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Put a plastic bag over the end of the trans to trap any oil. Use electricians tape to wrap around the bag to the trans.npull the bag tight, dont want any more space for oil than necesary.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Sounds like a good excuse to buy a 60 gal shop compressor to me. (y)
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Neautral.
Small container if your scared.
Junk Collector
Truck of Month
4,800
Rapid City SD
Alwaysfloored has it nailed... bag it and run it.
superj
2,577
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
Or a 20oz soda with top cut down and stuffed in place of the output
franklin2
1,758
Virginia
Bronco II
Whatever you do, it's going to make a mess. Been there, done that. When I did it the mess wasn't too bad, a bunch of oil speckles all over the frame and the floorboard underneath.
