Right Rear tire wearing very aggressively
jlb0716
Eastern NC
2.5L
I have an 01 4x2 Ranger XLT with 4" of lift. I am having an issue with the right rear tire wearing alot more than the rest of the tires. What could be causing this issue and what can I do to correct this problem.
multiranger
Praise the Lowerd!
MTOTM Winner
17
Loganville GA
Doing "peelouts" and barking second and chirping 3rd? That is what caused wear on mine...
Ranger44
23
Illinois
FORD
4.0 OHV
Rotate. Have you had an alignment?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
How is it wearing? Evenly or more on one edge or the other?
straycat
77
02 06 and 2012
Jeeps
Could be a shock as well. Something is causing the wear. Does the wheel/tire look like it is at an angle (bowed in or out)?
straycat
77
02 06 and 2012
Jeeps
Post a photo of it, Bro!!!!
jlb0716
Eastern NC
2.5L
the outside of the tire is wearing faster than the inside of the tire, I am working on getting some pics up in the next few mins...
i only have my phone to take pics with, cant find my camera so these pics may suck and not serve for much help but we'll give it a shot.
jlb0716
Eastern NC
2.5L
jlb0716
Eastern NC
2.5L
the tire does not seem to be bowing so im at a loss, not sure what to do to try and fix this problem. it cant be the shocks because I put brand new shocks on it less than a year ago.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Can't really see much detail in those pics...
What I can see looks like the normal wear that occurs when you don't rotate the tires often enough...
Your right rear tire tends to wear slightly faster than the left due to the weight shift that occurs from the driveshaft torque twisting against the axle housing while accelerating (especially if you have a standard open differential). The tire also has a little more wear in the center because the rear is so lightweight.
I'm thinking you just need to rotate them more often.
jlb0716
Eastern NC
2.5L
should I air it down a tad
jlb0716
Eastern NC
2.5L
I checked that about 3/4 weeks ago when I replaced the U-Joints on the driveshaft
jlb0716
Eastern NC
2.5L
everything seemed to be tight to me, no wiggle. I would rather work on my stuff myself than have a shop do it, but if its something I dont have the resources for then i guess i have to take it to them.
