Request help in identifying leak
JohnRgr2005
Panama City Fl
Ranger XLT 4x4
Hello, 2005 Ranger XLT 4x4 4.0l
New to Rangers And 4x4, found leak and requesting help in understanding cause and what may be needed to fix. Posting some pix.
Thanks
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,509
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
The rule with oil leaks... they travel down and blow back. The one picture appears to show a leak above the trans pan (the picture appears upside down). I can see trans fluid on the case above the pan.
Uncle Gump
Token Old Guy
13,509
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
It alsoo appears that someone before you used some sort of RTV to "glue" the trans pan. I never use any kind of sealant on transmission pans. Just an FYI...
JohnRgr2005
Panama City Fl
Ranger XLT 4x4
all photos correct orientation, taken from below. Truck has 75K miles . May be a dump question, but is this the "transfer case" or the transmission?
JohnRgr2005
Panama City Fl
Ranger XLT 4x4
Crawled back underneath (like that there is enough clearance to do that)
took some additional pics. thinking maybe the front input seal?
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
looks like the pinion seal in the front differential.
differential lube has a very unique smell, it's very pungent. what does this stuff smell like?
also has oil around the cover of the diff, so that's kind of contradictory.
clean it off with a solvent, then see where it comes back from.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,707
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I'm leaning toward a differential leak as well. Looking where the majority of the fluid is, does look to be a pinion seal leak like you guess. I agree the OP needs to clean everything off with brake cleaner and see where the fluid comes back first.
JohnRgr2005
Panama City Fl
Ranger XLT 4x4
Thanks guys. I have to ask if it is a bad leak or can I drive it ?
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
gear oil is thick and ooses out slowly.
go by the puddle where you park it. just dots I'd drive it.
a puddle you need to walk around warrants checking fluid level.
it never hurts to check the level, add until it runs out the fill hole. you'll need a hose.
JohnRgr2005
Panama City Fl
Ranger XLT 4x4
Just noticed dots where I park at work. Thanks
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Dots add up eventually. Check your levels accordingly. If you can't tell where the drip is coming from, get some degreaser cleaner like "gunk" spray the whole undercarriage and engine then clean it off. Take a small trip, 25 or so miles, then look again for where the drips are coming from. As @Uncle Gump said, "The rule with oil leaks... they travel down and blow back."
JohnRgr2005
Panama City Fl
Ranger XLT 4x4
Follow up
cleaned off with brake cleaner (worked great)
Topped off Front differential with 80-90Wt API Gl-5 Gear Oil
went for ride apx 40 miles photos attached.
From what I see the oil is coming from rear of differential
Looks like you guys were right and most likely pinion seal leaking
