replacement seat belts
xfrog
looking for a set of replacement (factory style) front seat belts for my 1993 ranger. Mine are worn, stained, and the driver side doesn't want to retract like it should. Any sources out there for replacements, that won't break the bank?
tinman_72
139
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
I spent months looking for a new set for my '93. You won't find any new. Try Ebay, or junkyard. I ended up pressure washing a set from the local Pull-A-Part.
jhammel85
Guest
I wouldn't get them from a junkyard. You never know, they could been used in an accident. Better safe than sorry..
LMC truck has them. They're expensive.... But JC Whitney has universal 3 point seat belts just like the OEM ones. I have them in my truck. Worst part is getting the bolts through the body off. Use a torch to loosen up the locktite. I actually had to drill one of the corroded bolts out on mine.
http://www.jcwhitney.com/beams-universal-3-point-retractable-seat-belt/p3046446.jcwx?filterid=c3267d658u0j1
xfrog
