Replaced passenger CV axle, now it leaks 2000 Ranger
icephreak
Priest River, Idaho
So I replaced my 2000 rangers front passenger CV axle because the boot was torn. When I pulled the shaft out the whole internal shaft came with it, I slipped it on the new cv, slipped it in and everything went in smooth. Now I've got a constant leak of differential fluid coming out of the tube and dropping off the CV. Anyone got any ideas why this is happening? Thanks.
pjtoledo
2,968
Toledo Ohio
Fords
3.0 2.3
did you tear up the seal in the end of the tube?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Yup, sounds like you need new shaft seals. But I have seen residual fluid left in the tube look like its leaking. I'd clean it up real good and if it still keeps leaking replace the seals.
icephreak
Priest River, Idaho
Looks like I'm buying seals, will I have to take the whole diff out to replace them? Also, is it normal that the whole internal shaft came with with the cv or did I break the clip inside?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Front axles dont have c-clips the axles are held in by the hub/wheel bearing. Similar to a full floating rear.
icephreak
Priest River, Idaho
Do I have to take the whole diff out to do the seal?
pjtoledo
2,968
Toledo Ohio
Fords
3.0 2.3
no. once the CV assemblies are pulled the seals are accessible. the seals are cheap.
since 2000s can be either setup, do you have pulse vacuum hubs or live axles with the big nut in the middle?
