Removing spray paint from plastic
Uncle Gump
Token Old Guy
13,471
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
So... one of the stores I maintain was broken into two nights ago. I was there yesterday to fix a couple things but they actually spray painted the plastic domes on the cameras with cheap black spray paint. I tried test spots with some brake clean I had on the truck along with a bottle of dollars store nail polish remover. Both of those fog the cover.
Any recommendations on what won't hurt the clear plastic but get the paint off?
Ramcharger90
1,708
N/A na
306, Bcam,
There was a paint stripper that came with the duracoat for an old rifle I restored once. It took the paint right off the plastic. Maybe look at that stuff.
Or easy off I remember reading once.
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Rubbing alcohol can remove paint. It's takes some rubbing but it will remove it.
duffy
19
Hot Springs, SD
Ford Bronco II
Mineral spirits or de-natured alcohol and some elbow grease might do the trick without damaging the plastic. Paint strippers etc will damage the plastic.
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Brake fluid... it won’t hurt most plastics.
Shadowrider6661
D RANGED
ASE Certified Tech
129
Off grid Northern Arizona.
Stock
4"
N/A
33 x 12.50 x 15
Drive it, Break it, Fix it, REPEAT !
This is just a suggestion. Since the lenses are plastic, you can use a fine rubbing compound to remove the paint. I've used it to restore old emblems on cars that are impossible to find. Any good plastic can be polished crystal clear using a fine rubbing compound for automotive paints, I use a dremel with a soft polishing wheel to make it easier.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
This. A headlight polishing kit will have it all
Shadowrider6661
D RANGED
ASE Certified Tech
129
Stock
4"
N/A
33 x 12.50 x 15
That'll work too, just didn't cross my mind. Sucks to get old, the mind goes first.
Uncle Gump
Token Old Guy
13,471
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I wish I would have brought them home with me to try some of these methods. But I left them in the store.
I used easy off oven cleaner before to remove some painted on lettering.
I got a bag of tricks to try tomorrow including oven cleaner... alcohol... rubbing compound... I'm also thinking maybe some Coleman fuel.
snoranger
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
The guys who restore old radio control cars use brake fluid to strip the paint off the plastic bodies before they repaint them.
Uncle Gump
Token Old Guy
13,471
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I forgot to add that I have a bottle of brake fluid too. Thanks.
I was going to just order new domes... but the boss said try to clean them first. I get paid by the hour... whatever he wants.
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
They make cleaners for removing graffiti that would work. But they might cost as much as buying new domes, or maybe not.
Roert42
4,961
Kintersville, PA
Ranger XLT
4.0 SOHC
Goof off or goo gone.
Uncle Gump
Token Old Guy
13,471
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Hell... never thought of goof off.
In the bag...
Uncle Gump
Token Old Guy
13,471
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I'm probably not getting back to that store until next week. The problem got a bit worse then just cleaning the domes. It got broken into a second time... the same people... but this time they spray painted the cameras themselves. Looks like it will get new cameras now.
Cops picked up two people yesterday... a recently fired assistant manager and a crew person still employed there at the time of the second break in. Seems they would leave the back door to the service hall unlocked and use a piece of cardboard to defeat the lock on the service hall entry door.
I guess what they didn't take into account was the surrounding businesses and their cameras...
