Remote Powerlocking Question
Charlville
UK
2.5L
Hi
I have a 98 XLT regular cab.
I need to know if I have remote power locking installed as I don't have the remote control?
The truck has power windows and locking operational via the rocker switches on the armrests.
I have two keys but neither of these have remotes included.
My question is does anyone think that I may have the facility installed but just need the remote, or is installation needed?
Thanks in advance.
Jay FX4
25
Dearborn, MI - Home of the Blue Oval
I have never seen a Ranger with power locks that doesn't have the keyless entry remote. I'm not an expert on 98's but I would think there should be a remote. I would suggest taking it to a dealer if that's the case.
Better yet, get a good alarm system installed. That's something every Ranger owner should invest in.
Charlville
UK
2.5L
Thanks
Thanks for the reply.
The alarm is on the agenda.
The dealer thing is a little more difficult as I'm in the UK :)
UK Ford dealers don't like US stuff too much!
flyingbrick
Winnipeg, MB, CA
Try this.
To program the transmitters yourself:
1-Insert a key in the ignition and turn from 3(Off) to 4(On) eight times in rapid succession (within 10 seconds) with the eighth turn ending in the 4(On) position.
2-The doors will lock/unlock to confirm that programming mode has been entered.
3-Within 20 seconds, program a remote transmitter by pressing any button on a transmitter. The doors will lock/unlock to confirm that the remote transmitter has been programmed. (If more than 20 seconds pass before pressing a remote transmitter button, the programming mode will exit and the procedure will have to be repeated.)
4-Repeat the previous step to program additional remote transmitters. The doors will lock/unlock to confirm that each remote transmitter has been programmed.
5-When you have completed programming the remote transmitters, turn th ignition to 3(Off) or wait 20 seconds. Again the doors will lock/unlock to confirm programming has been completed.
That's it!
Yes it is how to program the remotes, but it should tell you if you have keyless.
plainsranger
Guest
If its a US built ranger, the 98 model year came standard with remote keyless entry on the XLT models.
Charlville
UK
2.5L
Excellent information thank you!
I'll try it and see :)
Charlville
UK
2.5L
Tried the ignition on and off process but the truck didn't lock/unlock.
Do I have any other way of checking please?
flyingbrick
Winnipeg, MB, CA
That's the only way i know of, maybe someone else can step in with an idea.
Cacher
Manitou Springs, Colorado
Pull the door panel and see whats inside the door and connected to lock linkage?
IRKillroy
6
Okinawa
2.9l
Semper Fidelis
um, seriously? call a US ford dealer..... you need a number?
LS-300
Just tried this and it worked for my 2002 Ranger. Only thing is if you have more than 1 remote they must be reprogrammed at the same time.
