Rear drums not bleeding. Line has no fluid
RustRatz
22
Arkansas
Ford ranger
Rear drums won’t bleed, and I unscrewed the brake line and there’s no fluid. Reservoir is full.
1992 Ford Ranger 2.3 5 spd.
snoranger
Professional money waster
ASE Certified Tech
13,729
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
First place I’d check is the RABS valve. I’ve had 2 of them screw up and block flow to the rear brakes on different trucks. I replaced 1 and pulled the other one apart, cleaned, and reassembled it.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,595
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
It's either the RABS or the rear brake hose.
Uncle Gump
Token Old Guy
13,595
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
On the frame rail below the master cylinder. Just follow the rear brake line.
RustRatz
22
Arkansas
Ford ranger
Found it. Should I replace it or figure out how to take it apart and clean it?
snoranger
ASE Certified Tech
13,729
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
The choice is yours… the only reason I didn’t replace the 1 is because it was Sunday and I needed the truck for Monday.
Josh B
1,988
Oklahoma
It is a total pain to get to, pull the starter and multiple lines.
I'm not certain if I ever even got mine out, just drove it onward through the fog, but that told on me today. Tomorrow I'll have to tear down my rear drums and see what's come loose in there, thankfully I managed to drive it the last 20 miles with no serious incidents, I won't know till I see in what happened, but I am presuming it's something brake related :/
RustRatz
22
Arkansas
Ford ranger
Replacing it would cost me a minimum of $170, and I don’t exactly want to waste a quarter of my paycheck on something I can rebuild for $20. I do have an old parts truck that I can check to see if it still has it’s RABS.
Uncle Gump
Token Old Guy
13,595
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
You could try disconnecting the brake line from the rear hose to see if you get fluid to that point before replacing the RABS valve. If you get fluid there... it's the hose has collapsed.
RustRatz
22
Arkansas
Ford ranger
will do. Purchased a used RABS for $26 from the local junkyard, looks like it’ll flow fluid
Josh B
1,988
Oklahoma
Rattle it around a bit, tap tap tap, whatever, soak it in something, they are bad about stopping up if not maintained
From what I have read on some posts not on this forum they are just as well routed around
RustRatz
22
Arkansas
Ford ranger
I believe the previous owner didn’t take much care of the truck as it had a knocking 2.3 and a huge oil leak when I got it. Had all 5 gears and reverse though.
Josh B
1,988
Oklahoma
I believe there is a valve or gateway of sorts inside it that should rattle a bit when shook, maybe, if I am not totally mistaken :D
