Rear drums are sticking
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,810
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Please don't remove the parking brake, if people ever saw the park pawl in an automatic transmission they would never park on a hill without setting the brake. And if the hydraulic brakes should fail, having minimally effective mechanical brakes on only the rear wheels is way better than no brakes at all. And yes, I've seen full hydraulic brake failuers, usually after a "tech" at Jiffy Lube topped up the master cylinder with power steering fluid.
I’ve also seen a parking pawl fail on my neighbor’s truck. Thankfully, the only thing that got hit was a tree in someone’s front yard. I don’t think the neighbor learned from it though. I don’t recall ever hearing him set the brake.
KornTruck2
25
Chicago
I am not lobbying to not use it. If it is true that its the parking brake cable, or “parking brake system”, it would be nice to validate that. If i take that out and my problem goes away, i can get replacement cables, mine is tore up anyway
KornTruck2
25
Chicago
It totally was the parking brake cable. My truck has 247k on it, when the trans lets go, i am manual swapping it. I will fix the ebrake, swear on things important to me. Thank you guys for the help, much appreciated!!
Uncle Gump
Token Old Guy
13,590
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Once you're sure the parking brake is fully released I'd look at the brake adjusters. I've never seen a setup like that on a Ford, did the old parts look the same?
I just did complete brakes on my 8.8 with 10 inch brakes... same set up. The 9 inch look a little different.
@KornTruck2 glad you got it figured out.
Be safe out there...
KornTruck2
25
Chicago
I got plans for this truck
sgtsandman
Ham Radio Operator
12,810
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
If you are going to do a manual transmission swap, you definitely want to make sure the parking/emergency brake works. You do not want to depend on engine compression to hold a vehicle in place.
KornTruck2
25
Chicago
Cable is already ordered, amazon had it for $35. All about a good functioning vehicle.
