rear disc conversion
jerkyboyxiii
89
nebraska
ford ranger
I swapped my ranger to the SSBC rear discs. The rear rotors are 10.5. I have a set of front rotors that are drilled and slotted. These are 11.22". My lift was just installed and they upgraded my front rotors to 12". Will I be able to use my existing 11.22" rotors in the rear as an upgrade?
Josh B
1,986
Oklahoma
Wow man, how much did that 3/4 inch cost? Did it really make any difference for braking?
Uncle Gump
Token Old Guy
13,478
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Is this the Rough Country 5 inch lift... that requires 17 inch wheels?
As far as the upgrade to the rear brake bigger rotors... it will most likely depend on the caliper brackets.
jerkyboyxiii
89
nebraska
ford ranger
I forgot how much it cost to snag the conversion kit. I bought new rotors n pads before I had the lift put on. The shop upgraded to 12s per the suggestion from Rough Cuntry. I now have a set of drilled and slotted rotors with no purpose, unless I can repurpose them for the rear. I also did not have to swap the proportioning vlv, as was also suggested. My brakes are killer at the moment.
jerkyboyxiii
89
nebraska
ford ranger
Gump, correct, sir. RC does specify 17" wheels, but my 16s cleared with no problem. Once I get 500 miles on the lift, I will drag the ranger back into the installer and they'll retorque everything. After that, I'll put the 2" spacers back on. The shop did replace my calipers bc one had a cracked mount. Maybe they chose to upgrade at that point.
Josh B
1,986
Oklahoma
That makes sense, I hope that works out Jerkyboy. sounds good actually
sgtsandman
Aircraft Fuel Tank Diver
12,652
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The brake systems I've seen on the Rangers and Explorers that have disc brakes will not support using front disc rotors on the back. The rear brakes on the Rangers and Explorers use the center hat as a drum brake for the parking brake system. Even if all that were to work, the width of the rotor will be too wide for the rear brake caliper to fit over. The 2010 and 2011 Rangers, while using vented rotors, are still narrower than the front rotors. The Explorer rear discs that I've seen aren't even vented. Just a 1/4' - 3/8" solid disc.
I can't say if a Mustang brake conversion will support them or not. I suspect they would not.
rubydist
858
Denver
Ford Ranger FX4
Without knowing exactly which kit you have, we cannot answer the question. It will depend on two things: if the caliper brackets will allow you to mount the calipers outboard about another 3/8" to clear the larger discs, and if the caliper opens wide enough to accept the thickness of the (formerly) front rotors. Most likely the answer will be "no".
jerkyboyxiii
89
nebraska
ford ranger
Thank you, gents. Im curious, so i will definitely get out my measuring stick:)
don4331
1,346
Calgary, AB
5.3
@jerkyboyxiii : The height (distance from mounting face to outside of rotor - kind of equivalent to wheel backspacing) of Mustang rotors is ~2". The height of your front rotors is almost 2-5/8" (2.600). I don't think spacing caliper off 5/8" is worth the extra braking (not exactly safe).
