Ranger’s frame width
MyWifesHotPocket
5
Virginia
Ford Aerostar
I’m spit balling an idea here and it involves an Aerostar and a D35 TTB setup. I want to know what the frame width is on a ranger as well as the coil bucket dimensions. I doubt it’ll line up perfectly as I know it’s not a bolt in deal, but it would give me an idea as to how much work would be involved.
thanks!
franklin2
1,774
Virginia
Doing a google search, the track width of the aerostar is 61.5 inches front, 60 inches rear. According to this link the ranger is a little bit narrower, but grew as you go to the later models.
arse_sidewards
4
The People's Rupublic of Assachusetts
300ci
Not to be too much of a naysayer but this probably isn't gonna work out and if it does it probably won't come out nice without a TON of fab work thrown at the chassis to make the TTB fit into it.
Track widths are comparable enough to probably work. You're gonna have other problems though.
The Aerostar "frame" width is much wider (I can measure later if I remember) and will conflict with where the coil buckets want to be so you need to move them out or go coilover.
If you intend to build an off road Aerostar you are going to be stuck either running tiny stock-ish sized tires or having stupid amounts of lift because there is close to no space between the front tire and the driver's left foot so you'd need to modify the firewall if you wanted to be able to cycle, let alone turn, a 29" (i.e. stock size for Ranger) tire. The wider frame is also somewhat of an annoyance for the radius arms because it moves them outboard which also has the effect of limiting steering even if you do cut up the firewall. If you do choose the "stupid amounts of lift" route you'll have to address the rear because the rear because all the control arms are really short because this was only ever intended to be a street car. Making longer lower links and new mounts is a simple fab project. The upper will be a packaging nightmare because there's a gas tank in the space you would want to move it to.
I briefly considered doing a similar swap and concluded that it would be a massive PITA no matter how I did it and that tracking down a 4WD Aerostar donor for all the front end stuff would be the least crappy solution. The second least crappy solution would be getting a 4wd Explorer/Ranger torsion bar front subframe and arms and just cutting, modifying and welding until it fit well enough. I think that solution would be overall cleaner than trying to fit a TTB into a chassis that really, really wasn't designed for it.
I wound up concluding that all things considered if I wanted to build something fun that dumping in a hot 302 and laying rubber everywhere would be the all around better option.
If you want a big floppy off road box buy a Cherokee. If you want a small floppy off road box buy a BII.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Welcome to the site.
MyWifesHotPocket
5
Virginia
Ford Aerostar
the aero I have is an e4wd version and I have lifted it 3 inches sometime ago, it has 235/75r15s on and doesn’t rub. I actually have a Cherokee as well haha, it’s good, it’s a very good platform. But it is too small for when I need to haul stuff and the price of a decent e/f150 that isn’t rusted out in my area is too damn high than what they’re worth. But you are right, mounting a ttb with the way the subframe is designed on that van would be a massive headache. I’m guessing a Dana 30 would be a better option.
maybe a Dana 35 sla would be sufficient for now. I’m swapping the transfer case so I’ll have to get different prop shafts anyhow.
Roert42
5,031
Kintersville, PA
Ranger XLT
4.0 SOHC
Whatever you do you should post up some pics and maybe a build thread. There is a section for non ford truck builds, and a lot of people that are interested in mechanical explanation.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Curious. Didn't Ford make an all-wheel drive Aerostar? I only ask because GM made AWD Safaris and Astro Vans.
MyWifesHotPocket
5
Virginia
Ford Aerostar
thanks, I’ll check that section out. Nothing is really set in stone with this yet. What arse_sidewards suggested with swapping a 302 in seems more fun to be honest, It’s not like I go rock crawling or mudding everyday.
Ranger850
Doesn't get Sarcasm . . .
4,699
Tallahassee Florida
Stock 2"
Stock
Fully optioned XLT , allegedly
MyWifesHotPocket
5
Virginia
Ford Aerostar
they did, it’s called e4wd. It’s okay, I guess. It has the Dana 28-2 (SLA) in the front and uses cv axles. The transfer case has a high percentage of magnesium and is very prone to cracking. There’s no option to turn it on without wiring a button in or making the rear wheels spin.
snoranger
Professional money waster
ASE Certified Tech
13,724
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
RuleBreaker built an offroad Aerostar, you might want to check out his build thread:
MyWifesHotPocket
5
Virginia
Ford Aerostar
it’s a shame that the photos have expired in that thread. I’ve been reading up on that one for a while though, thankfully it seems he has left enough information to type up a mock write up. I wish I could get in contact with the guy, Im guessing his inbox is chock full of others asking about that van. Thank you!
snoranger
ASE Certified Tech
13,724
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I think I still have his phone number… I’ll see if I can get him to check in here.
4x4prepper
216
Atlanta
I did not know that, my 1995 EAWD (e=extended not electric) made it to 180,000+ miles with no problems, including off road and through the fields. I worked at a MASS Ford dealer and never saw a broken transfer case. Though there were one or two people that needed the Dana 28 replaced because they never changed the fluid (or checked it).
Running 235s is impressive, I have bought these tires for my F-150 I am restoring, though I use to buy the 235s from treadwright instead with the kwedge grip, but, I guess they have given up on 15" tire support.
Just swapping in a manual transfer case from a B2 or Ranger? Always wanted to do that with mine, especially after I nuked a front hub/axle and learned the only way to disable the AWD so you can actually drive it is to remove the fuse under the driver's seat.
