Ran into this problem
9
St Petersburg, FL
2.3
So everything is going smoothly swapping over parts from my stick 90 2.3 to my automatic 2.3 and i ran into the crank insert is not wide enough to fit the torque converter. Im assusuymming i going to have to get deeper is thise and machine the crank or i have a crank from my other 2.3 with correct width. Or is there a torque converter that has smaller insert?
Transman304
43
Morgantown WV
Chrysler PT
2.4
If you can’t fix it with a hammer, you have an electrical problem
Take the pilot bearing out of the crank.
9
St Petersburg, FL
2.3
Thanks Trans man I just releazied i left pilot bearing in. happens when i get in a rush
