Radius Arm Bushing's Squeak
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
My Ranger squeaks like a civ when the front end flexes while I go over bumps, etc. The bushings appear to be in good shape, and I hear no clunking like my old Explorer did. I've tried to put WD-40 on them, but it only lasts a couple of weeks. Is this a common issue that can be resolved? Or should I bite the bullet and replace them? Thanks!
BlackBII
Ranger Custom
Truck of Month
982
UT
Do you have the Rubber or Polyurethane ones?
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
They are factory, so I guess those were rubber?
ThatGuy
11
Oak Ridge, TN
Time to replace.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
OK, sounds good. Is there a "how to" somewhere on TRS? I looked in the tech library and didn't see anything (I have been known to look right at something I needed and not see it). Those rivets on the top look like a pain to get out. Is there an easy way? Thanks a ton!
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Grinder, Air chisel, and/or drill.
Removing the radius arm crossmember seem to be the easiest way to replace the bushings. Replace the rivets using 7/16" bolts.
legoms013
09/2013 OTOTM
26
CA
4.0L V6
No there isn't an easy way. Either torch them off or get a grinder and cut at X in the them and air chisel them off. Replace with a minimum of grade 5 bolts.
BlackBII
Ranger Custom
Truck of Month
982
UT
Thats the hard way....
Jack the up truck under the axle and then unbolt the radius arm, tie rod, shock and sway bar and let them all just hang there. Put some jackstands under the frame and lower the axle down. There will be enough play to pull the axle forward just enough to get the new bushing in. Easy. Done it many times
One side at a time of course.. id rather do that than grind out some rivets..
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Is any brand of bushing better than the other? I usually lean towards Moog on suspension parts.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Do I need to do anything with the spring?
Downey
Muncy, PA
im running james duff bushings i like them
Downey
Muncy, PA
screw that its two easy to take out 4 rivets and i trust bolts more than rivets.
BlackBII
Ranger Custom
Truck of Month
982
UT
It will just drop out of the coil bucket.
And 4 bolts sounds a lot easier to me than 4 rivets.....just sayin..
:icon_bounceblue:
8sechonda
when i bought mine it was squeeking also,.. bottom ball joints was bad.... replaced and no more squeeking...
