Is it possible to pull the 4.0 and A4LD out of a 92 ranger together without taking out the radiator core support? This truck has no lift whatsoever on it.
It's definitely doable, I pulled a 2.8, A4LD, and t-case out of a BII a couple months ago without separating them. It helps to have the front wheels of the truck on some boards so it's a little higher, and someone underneath to push on everything.
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
