Pulled engine codes
michowski
OK my check engine light has been on for a little while now. Ive got the codes and looked em up and got the following....
117 (O,M) ECT sensor is/was low or grounded - ECT
218 (M) IDM signal open or high or left coil pack failure - Ignition Systems
171 (M) Oxygen sensor not switching - system was at adaptive limits - Single, Right or Rear HO2S - Fuel control
177 (M) Oxygen sensor not switching - system was rich Left or Front HO2S - Fuel control
116 (O,R) Engine Coolant (ECT) sensor out of range - ECT
172 (R,M) Oxygen sensor not switching - system is or was lean - Single, Right or Rear HO2S - Fuel control
538 (R) System did not receive "goose" test - TESTS
536 (O,R,M) Brake On Off open or shorted to ground - BOO
Oxygen sensor is easy to fix. My question is how do I fix 117, 218, 536. I had 116 before and changed the sensor by the thermostat housing. Thats brand new and the code went away after I changed it. Now it came back. Is there something else for that? Also I have disconnect the battery and let the computer reset and drove it a for a day before pulling these.
almostclueless
You really need to look at a wiring diagram and see if there is any common item for all these.
Ranger44
23
Illinois
FORD
4.0 OHV
That's what I'd do.
2000fuelishdreams
O'Fallon Missouri
check with the online service manual i posted about (the holy grail post) and you should be able to find something on it. good luck.
Hardwareman
SoCal
MAN!!!
That's a lot of codes! I don't think I've ever seen that many in one shot before. You win the crown.
Allen
michowski
Changed the 2 o2 sensors on my truck and so far I havent seen a check engine light. Im gonna pull new codes later and see what happens.
