Project Power Ranger
mnfirefighter
Project - 1994 Ranger 2.3 turbo
Never really have taken on a project like this on before but I've torn apart my 7.3 powerstroke and several other vehicles before. Got a junky Craigslist Ranger that barely runs - got a 2.3 turbo from a 1986 Mercury Cougar XR7. The project started because well I had the motor and wanted a little beater truck. I've done some research and will be using the 5 speed that is in the Ranger. I've read up on the work to do the swap and the biggest challenge will be the wiring because I don't have any wiring from the XR7.
Where I sit now - NA 2.3 pulled from Ranger, Ranger wire harness pulled out, I have a LA3 ECU to use and a big VAM. The XR7 2.3 came with the brown top injectors. I want to get everything up and running then I'll eventually lower it.
I have a lot of information on what I need to repin, what I need to add for wiring and so on. The biggest challenge I see will be the ignition wiring since I'll be going from DIS to TIF (I think I'm correct here). I'll update this as I go.
Any knowledge on this you want to share then shoot away
Cody L
Waterloo, IA
2.3T
I also converted from DIS to TFI. Was not hard at all. I used the ignition wiring from a 2.9 ranger along with the coil bracket for the fender.
Sent from my SM-N920R4 using Tapatalk
mnfirefighter
Finally got some time to post an update - pictures of everything
- I rebuilt the brakes and replaced the brake cables - they broke off inside - I included some pictures of the spring layout for others to reference - I simply used the spring removal tool and removed all the springs then behind the pads there is a lever with a flange that the brake cable attaches to
- I will be replacing the shocks
- ground off all the rust chunks and then used a rust converter I brushed on - it works really well - the rust turns black and it chemically acts as primer - a couple of the pictures show the frame grey - i simply threw some primer on it when i took the bed off and stored it - i then ground off the large chunks of rust
- Then POR15 base coat then POR15 chassis top coat
- new bushings for leaf springs & bolts
- new u bolts
- replaced the drivers side front hanger that rusted out - I had to weld up some rusted out areas - I made a welding cart w/ a toolbox built in:icon_welder:
- I have new gas tank straps since they rusted out and broke when i removed them
- After the gas tank is back on then I'm power washing the engine bay and will start the engine work and eventually wire harness
mnfirefighter
Finally got the rear end where I want it for the time being. Now ready to toss the box on. I haven't been able to commit hardly any time to this between remodeling the house and work. But here we are. Next is to save money to start the rebuild process of my 2.3 turbo.
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
8,756
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Fun with wires :)
7
Alabama
2005
Nice man, your taking time to make it last. And wires are a headache. Keep posting pics i would like to see what you do under the hood.
