KELLY88
- Feb 26, 2008
- 4
- Lake Mary/Daytona Beach, FL
- Ford
- Engine Size
- 4.0, 4.0
Well this has been an odd problem that's gotten worse over the last month. In the beginning, every once and a while, when I go to start the truck it would crank once, hesitate a bit, crank a few more times then fire right up. Problem is that I lost power in that hesitation. The radio and clock would reset like what happens when you unhook the negative battery cable. It used to be a once in a while occurence but now it happens almost every start up.
Another problem going along with it is that if I shut the truck off and try to start it again in under a minute it won't work. It cranks a few times then clicks like the starter isn't engaging. It'll work after about 2 minutes of waiting but with a lot of hesitation. It starts best after it's sat at least an hour.
I thought maybe the battery terminals were just getting a bad connection. Cleaned them up, problem still there. I'm pretty limited on electrical know-how so any input would be great.
