- Sep 22, 2007
- Reaction score
- 7,605
- Location
- Michigan
- Make / Model
- Ford
- Engine Type
- 2.9 V6
- Engine Size
- 177 CID
- Manual
- 2WD / 4WD
- 2WD
- My credo
- A legend to the old man, a hero to the child...
Even with the vacuum hose completly unhooked it just pushes 42psi or so.Yes it is in fact a factory 2.9 v6 i was just mentioning i had other engines to swap but no time for it.
Ill take a look and see what the pressure is. Curious if it could be the regulator restricting flow untill vac gets high enough to force it open?
Also anyone know of a smoker kit to check for leaks? Would be super cool if i could rent one
I think fuel delivery is just a symptom of something else. Take some ether and spray around the upper intake bolts...while the motors running.
If it revvs up then you got a leak in the gaskets.
