Pittman arm
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
got it all back together but cant seem to get the high pressure line connected to the gear box to stop leaking. Used Teflon gas tape and still a leak. The fluid is coming from the steel line not the threads. any suggestions. The line is new. Dirty.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Check to see if there was an adapter on the old box. Sometimes they have different fitting types and the line wont seal if it's not the right style port.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
No adapter, Dont think it has O rings or seals. Didn't see any when i took it off, Just a flare fitting.
19Walt93
4,500
Canaan,NH
351
3"
235/55R16
We used to routinely rebuild power steering boxes. Most often if the lower seal leaks you'll find the sector shaft is scored or rust pitted and I suspect replacement shafts won't be available anymore. Reman boxes are pretty cheap now.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Its not leaking at the pittman arm anymore. I bought a reman, leaking at the high pressure hose connected to the gear box.
