For Sale Pile of stock and aftermarket bits
zachwabbit
24
Jamul
Ford Bronco 2
Most of these parts are for 4wd and/or 2wd beamed Rangers/B2’s/Expos depending on year.
Pair of Autofab 2wd radius arms with bushings and stock crossmember/mounts for a 4” lift (off a ‘97 Ranger, was on my ‘89) $250
A second stock radius arm crossmember/mounts and A4LD trans crossmember(off an ‘89 B2) $50
Stock ‘89-92 steel hood, have latch and prop if needed. $50
Pair of Bilstein 5100 shocks for 0-4” lift $75
Stock 4x4 coil buckets(small section cut off one bucket at brake line clip area, also off an ‘89 2wd, but stamped 4x4) $25
4” drop pitman arm fits all power steering beamed Rangers and full-size ford Broncos/f150s) $40
Valley hitches 2” bolt on hitch for full-size Fords, came off a ‘93 F-150. $75
I’m in San Diego, local pickup or might ship some parts
Pics to follow soon
zachwabbit
24
Jamul
Ford Bronco 2
Oh yeah and I have three red Optima battery height adapters, and bunch of little snap on hold-down adapters (2 new, one used) $20 each for the height adapters, $15 each for the group-specific holders
One used James Duff radius arm crossmember/trans mount $40
One pair of brand new Alpena LEDClaw tube clamp light brackets $30
zachwabbit
24
Jamul
Ford Bronco 2
Here’s some more pics, hoods in good shape minus needing paint. Only surface rust, been stored in my dad’s sealed barn for a couple years out of the rain
bodied91ranger
202
maryland
ford ranger
would you be interested in shipping the hood?
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
sending pm on pitman arm, duff crossmember, radius arms
WreckingCrew
Jersey
Ferd
Are the coil buckets 25 each or pair?
scrapper
63
central IL
1975 302
does the trans mount bolt up like that or is there brackets? Any idea on shipping to 61756 central IL. also will it work with a c4?
bodied91ranger
202
maryland
ford ranger
hey Zach can ya send me a text 443 497 0063. need some info on that receipt that hood didn't make it to me and need to file a claim. not your fault but I gotta new phone and lost our messages with the receipt pic you sent... thanks
zachwabbit
24
Jamul
Ford Bronco 2
JD crossmember has been sold
sexybluelady
11
springfield, ma
ford, mitsu, do
Do you still have the coil buckets? and the shocks? You stated that they are stamped for 2wd but work for 4wd? The shocks will work fine for 4wd.
zachwabbit
24
Jamul
Ford Bronco 2
The coil buckets have been sold. And they were actually stamped ‘4x4’ but came off a factory 2wd B2. But yes I do still have the two Bilstein 5100s, and yes they will work fine for 2wds or 4wds
sexybluelady
11
springfield, ma
ford, mitsu, do
Sent you a pm. Thanks.
