Pictures of customized engines/bays
88xltranger
35
NC
Looking for some inspiration, Lets see some painted or modified engines and engine bays 😁 preferably 2.9s
19Walt93
4,467
Canaan,NH
351
3"
235/55R16
svtcards
137
Lyman maine
302
3'' front 4''back
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
How does that shrouded fan setup work for u? I read that shrouding it will overheat if your riding on the turnpike.have any issues with over heating at all?
Walt has never had an overheating issue with anything. Not even that one time he drove a Chevy.
svtcards
137
Lyman maine
302
3'' front 4''back
svtcards
137
Lyman maine
302
3'' front 4''back
Any idea what he's running for an electric fan or make of his setup?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Where the heak did you hear that? Pretty much everything ever made uses a fan shroud. :icon_confused:
svtcards
137
Lyman maine
302
3'' front 4''back
I meant the fully enclosed shroud.not the little plastic piece on top of factory ford ranger radiators.i saw it on YouTube from a summit racing rep.and a few other radiator companies as well
svtcards
137
Lyman maine
302
3'' front 4''back
I don't see alot of V8 rangers have shrouds do u?
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The fan shroud can be beneficial if the spacing is correct. If the fan is too deep or too shallow in the opening of the shroud, it can actually hurt instead of help cooling. Since the spacing is so critical, those who installed V-8s tend to not install the shroud because they can't get the proper spacing.
How the truck is equipped changes what the factory puts in. Trucks without A/C tend to have a minimal shroud, at least from what I've seen. Those with A/C tend to have a full shroud because more cooling is needed to compensate for the additional heat generated by the A/C unit.
svtcards
137
Lyman maine
302
3'' front 4''back
Thank u for the assist.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
