Parking Brake Cables w/8.8 Upgrade
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Ok gents, swapped the 7.5in out of my 1996 108in WB for a 8.8on l/s out of a 2001 x-cab.
Trying to set the new axle up, and ran into a bit of confusion with parking brake cables.
Unfortunately none of them survived the swap process (rust) with the exception of the front cable on the 1996. Got on Rock Auto to get new cables, and now I'm plain confused on which ones to use.
Available options from rock auto:
Any (useful, Dirtman ) input is greatly appreciated!
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,586
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I would buy rear cables for 10 inch rear brakes with 108 inch wheel base. Start there...
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Are the ones for the 7.5 and 8.8 interchangeable??
Uncle Gump
Token Old Guy
13,586
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I would think the difference is 9 or 10 inch brakes. But honestly... I'm not sure.
Did you try to mock up all the cables you had? Or did they get cut out?
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
All were chopped because I was fed up with trying to free them 😑😑😑
snoranger
Professional money waster
ASE Certified Tech
13,729
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Have you tried putting a cucumber in a bucket?
7.5 to 8.8 shouldn’t make a difference.
9” - 10” will be different.
Just get right ones for a ‘96 with whatever size brakes are on the axle your putting in.
Junk Collector
Truck of Month
4,862
Rapid City SD
^ what he said
Wheel base and drum size is the main thing. When I put the 8.8 in my stepside truck I think I used the passenger side one from my Explorer and one for an '88 short box w/ 10" brakes on the driver's side, works great.
Ranger850
Doesn't get Sarcasm . . .
4,699
Tallahassee Florida
Stock 2"
Stock
brakes are go "screech"
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,809
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Pretty much what they said. Match wheel base and brake size to what you have and it should be good.
