overheated, what problems can arise?
97ranger4x4
Sacramento
So I had a hose go out on me last thursday. Needless to say I saw my check gauge and was able to get it into a gas station with the needle pegged on Hot. pretty much all of the coolent came out so I was able to fix it and replaced the hose. Truck seems to run fine and doesnt feel like its lost any power or anything. I am just curiouse if there are any self tests I can do just to make sure nothing got really damaged. I am pretty pissed because I just replaced my upper and lower rad hoses and never replaced this smaller hose while I was at it.
Also as a worse case scenareo, what can go wrong?
:icon_confused:
Keith
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
Since the transmission cooler is built into the radiator, you may have overheated the trans too. I would change the transmission fluid.
Psychopete
29
FW, IN
Check your oil for coolant. If you wanted to get indepth with it, get a kit for testing coolant.
If it's not overheating, no oil in coolant, no coolant loss, not missing, and it's not (smoking and smelling sweet), you're probably OK.
Pete
MAKG
19
California central coast
A compression or leakdown test is also called for. The PCM won't detect excessive blow-by from a scored cylinder. Though it's unlikely to be an issue if your vehicle isn't consuming more oil than it used to.
97ranger4x4
Sacramento
okay thanks for the responses. I will check these things over the next few days. From the momment I noticed it was over heating I had it shut off in less than 5-10 seconds.
I was luckily in an area that I was able to shut the truck down immediatly. I have since gone and flushed the coolent system and replaced the hose that failed. I will check the oil and transmission fluid for coolent or any abnormal wear. I will also do a compression test and see how things turn out.
