Old school skateboards?
Ranger850
Doesn't get Sarcasm . . .
4,703
Tallahassee Florida
Stock 2"
Stock
I skated in the 90's. The trend was switching from the "fish" and "pig" to a "reversible" deck with no designated front or back. Tracker and Independent were the trucks to have and everyone wanted the "German" speed bearings. I was the first kid with the skinny and small ( 66 mm IIRC) "gizmo" wheels that didn't cone as bad as the older wider wheels. Veriflex was the "Walmart" brand. Last Christmas I got my kids skateboards, from Walmart. They had Decks by Vision Street Wear and were complete with trucks a and wheels for around $35. I clearly remember the decks alone could run $65. What a bargain. So I have done a few ollie's and kick flips in recent years but I dare not attempt any "real" tricks
Blmpkn
Toilet enthusiast
6,439
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Boxes of 100 NOS German speed bearings can be had for 200$ on ebay lol. Not an awful deal If they're good bearings.. I've never run them. Always been a bones reds kinda guy.
The vision street wear completes are their Walmart line essentially, the "real" vision deck is still 60$ for the popsicle stick shape up to 75 for old school shapes.
Its crazy that the price on skate stuff hasn't really gone up in.. forever.
don4331
1,357
Calgary, AB
5.3
i could never skate board either. but i used to do some cool crap on a bike. we would do the pools and half pipes and also try to jump over the telephone poles and from one side of the street to the other.
crashing on those types of jumps always tore you up though. i know that is why my wrists only bend to a 45 degree angle instead of a 90. the doctor thought i was faking and tried to pull my hand to a 90 degree angle but it didn't work
Once upon a time...
My brother and I found a little ramp - say 12" high, so we started jumping his banana bike over it, taking turns trying to set distance record.
But you can't really get going too fast on banana bike. But, from water skiing, we knew if when you cut across, you got good speed.
So, we found about 20' of poly rope, tied it to seat post of my 3 spd, and put a slip knot on handle bars of his bike.
Then we do test run at moderate speed - I ride down center of street, he cuts across, pulls the cord to undo the knot, hits the ramp and we trash the old record for distance. Time to get serious.
I'm going as fast as I can towing him, he cuts across. But the tension of the nylon rope has tightened it so tight that he can't undo it. He goes up the ramp, flying through air, but his bike is still attached to mine, so he only goes 20' then rope goes tight to my bike. He is swapped front for back and goes off his bike. Couple stumbling steps on road and he falls down into ditch. Rope has wound tight against my leg (nasty rope burn) before the force dumps me down onto the gravel road.
We get up, I'm bleeding shoulder from where gravel ground through my shirt, brother's bleeding from knees where he slid in ditch. Insert some cursing from big brother to little about not undoing rope before ramp. I have to stand on his handle bar to undo the connecting rope.
Pedal home to mom. She takes look at all the gravel in the road rash and decides we need to go to hospital.
At hospital, the nurse does the tsk, tsk and tells us the gravel needs to be removed or we will have permanent scars. She then hands me brass wire brush to remove it and steps out. I'm thinking she didn't want to see me cry, and I start rubbing out the rocks and let me tell you there is cascade of gravel as patch of road rash is bigger than my spread out hand and it was packed full. I'm watching in the mirror on wall to see that I am getting it all. A couple moments later, nurse comes back with the spray freezing. She looks at me, sets the can down, says, "It's almost done, no point in wasting freezing" and, takes the brush from me to finish removing the last fine sand from edges. I bite down on my lip, not a sound escapes (couple tears do roll down my cheeks, but I quickly cuff them away).
My brother is like I ain't that tough, and declines wire brushing. He still has pebbles embedded in his knee and associated scars, you can't tell anything ever happened to me. (No one told me chicks dig scars) She leaves room and you hear her tell doctor - those are some tough little boys, they'll be fine. Doc comes in, looks at it, says all nice and clean, you can leave now.
We stopped jumping bikes at that point. Skateboards didn't work well in gravel anyways, so I never got into it.
Friend fell on his skateboard at about same time - little road rash but busted clavicle.
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,878
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I haven’t been on a skate board since the ‘90s. Not that I was all that great anyway.
superj
2,735
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
Once upon a time...
that story could have easily been me and my friends and brothers, ha ha ha. i can picture all of it as i read your story. especially trying to jump and old schwinn with a banana seat and those short crank arms at the pedals.
my brothers and i were sitting on skateboards and riding down a big hill by the new house we moved to when i was in fourth or so grade. they were still young and one was going to kindergarten. since he was smaller, he decided to lay on the board, face first, to try and go faster. somewhere towards the bottom of the big hill, he hit gravel and the board stopped while he continued going. his face just slid down the road and his back legs were curled up behind him, in the pose we call the scorpion. half his face was gone when he stopped sliding and he was all bloody. he took off running home so i grabbed his board, my board, and my other younger brother with his board.
he has no scars now but he started school with only half a face because the rest was a huge scab.
i had so many bike crashes like yours. scraping rocks and sand out of road rash. i have scars all over though. the bad ones are motorcycle wrecks and skin cancer though
Ranger850
4,703
Tallahassee Florida
Stock 2"
Stock
Similar story : A school friend was visiting another family in my neighborhood. I was probably in the 2nd grade. The neighborhood had a road along the top of a hill and all the side streets ran down hill into a cul de sac. My buddy, hid dad, and his dad's friend, whom they were visiting, were all at the top and buddy was on a bike. Banana seat & long swooping handlebars, that we called "Chopper style". Dad sends it. After buddy got about 65% of the way down, the look on his face went from "CHEEZE" to worry to despair, as the handle bars started to wobble. His feet went out for the "Fred Flintstone" brakes and he ATE IT. He tried to use his hands to break the fall, but that didn't stop his face from connecting with the asphalt. When he finally came to a stop, he was screaming, bleeding, and freaking out at the blood. Dad & Pal were running down the hill and I just was staring at him. His face was raw, but not bleeding yet and I had never seen that before. That next Monday at school, he didn't even remember that I was there, even though we spent that whole day playing.
Blmpkn
Toilet enthusiast
6,439
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
I face-planted super hard off my bike a week or so before kindergarten.
My first school pictures featured huge scabs from my chin halfway up my cheek.
Wrecked a patch of my chin bad enough it messes with how my beard grows lol, such a bummer.
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
I never took well to board sports, much better at wheeled sports. Skate, snow, wake, surf etc...I can do, but suck at. Moto, bmx, mtb, etc is much more second nature to me. I'm better on two wheels than two feet.
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
I think that move is called the Miami Hopper.
Blmpkn
Toilet enthusiast
6,439
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
73392
Finally got all the crap in the mail to put this together.. still gotta put a set of rails on the bottom. Can't wait for the weather to cooperate enough to be able to ride the thing. Skateboarding was best before my time, absolutely.
