Nailzs
- Aug 8, 2007
- 0
- Age
- 37
- Ford
- Engine Size
- 4.0l
ok, first off, i have not put an oil pressure gauge on this thing
now, we all know that the 2.9l tick is caused by lack of oil pressure and a crappy lifter design. the problem im having is that my tick only happens at 55mph+, which equates to roughly about 2250-2500rpm +. after a few minutes of sustained driving on the highway, the tick gets bad, and i mean really bad, and when you slow down to an idle(like at a light) the engines sounds bogged down and like it basically underwater. but when u get back into city limits, after a minute or 2 of driving slower(lower rpm, im guessing more oil pressure to rpm ratio) the tick stops, the engine sounds fine, and runs fine.
im surmising that these 3 symptoms are caused all by the lack of oil pressure. hydraulic lifters and no oil pressure, generally oil starved valve train in general, means a crappy running engine. im not interested in fixing this - the bronco needs to last me another at least 8 months before i can either get something new or finally fix it. really, my question is what are you're guy's opinions on running a thicker oil, such as 15w-40, to boost the oil pressure and get oil to the valve train?
