Oil pressure and Water temp
CraKel
February 2010 STOTM Winner
MTOTM Winner
Ontario, Canada
5.OH
Hey, been reading on here and other ranger forums and have found a few different answers to the colour of the oem wiring for these gauges.
Installed a 79' 302 and trying to hook up water temp and oil pressure switch gauges. Can someone please give me some factual information on wire colours so I can hook these up to the stock gauges from the wiring harnesses located on driver side fender.
Ive read that water temp is black w light blue and oil pressure is either green w white or white with red..
I assume these are probably on the same connector ya? I think I found one thats white with pink but it didnt read anything when i hooked it up. Gonna use a voltmeter across them with key in accesory this weekend but just wanna make sure I get the right ones rather than splicing up 20 or so wires from the harness.
I think theres 2 black connectors and 1 grey connector.. is there a bundle that just has all gauges wires, cause that would actually make this alot easier haha.
Earl43P
38
Farmington, Pa
Ford F250 4WD
I'm looking at a 93 Ranger schematic,
Coolant temp sender wire is R/W (red wire with a white stripe)
Oil Pressure SWITCH uses W/R (White wire with a red stripe). Your V8's sender may be an actual sender. You could mod the dash gage to make that work or install the Ranger switch sender, which simply provides a ground to make the fake gage read mid-scale.
CraKel
MTOTM Winner
Ontario, Canada
5.OH
Ok great.. How would i go about mod'ing the dash gauge? I picked up a new oil pressure switch from napa. Not sure what its off of. Some ford no doubt but i needed a small one with 1/4" thread and this one is for light or gauge. I got one that was just for gauge but the housing was too big and it woundt fit in the hole because it was hitting the heads on the block. Its got an old style of connector on the top of it but with the right electrical connector it should work fine just as my coil does.
Are both the oil pressure n temp wires on the same bundle? I believe the numbers are c197 and c177? Any chance you could link me to a schematic? Thanks
Earl43P
38
Farmington, Pa
Ford F250 4WD
I can e-mail you the schematics (for 93).
PM me your e-mail adrress.
If your sender is for "light or gage", then it should work.
Link to oil pressure gage mod: http://rogueperformance.com/oilsw.html
No members online now.
