jeffw920
- Nov 15, 2009
- 1
- Ford
- Engine Size
- 4.0
hey, i was wondering if anyone could help me understand a little problem i had with the truck yesterday...
here's what happened:
got on the highway, accelerated at a pretty good rate to about 70, no problems, after about 2 min of cruising traffic came to a halt and everyone slammed on their brakes. I hit the brakes pretty hard but did not feel the abs go off, whether i locked up the rears idk but it is entirely possible. once traffic cleared and i accelerated again (pretty hard but not wot) my od off light began to blink and i lost 5th gear. I pulled over cycled through all gear selections and checked tranny fluid. my level seemed a bit high, about 1-1.5 inches over the crosshatched area. according to the previous owner fluid was last changed 40k ago, the fluid is blood red looks brand new and smells fine. after shutting the truck off and starting it back up it seems to run fine. Anyone experience anythign like this?
I've read that the abs sensor on the rear diff can cause the tranny to act funny when it goes bad. could someone explain the connection between the two to me? I'm hoping that would be the cause of this little issue. Again this only happened once, truck operates fine now but fluid does seem a little high (it was checked hot, but manual says to check it hot).
Should i go get it flushed, or drop the pan and check for anything obvious?
thanks for any input,
-Jeff
oh and specs on the truck to help out:
2004 fx4 4.0sohc, 5r55e
-Jeff
