- Jun 29, 2023
- 6
- Oklahoma
- Ford Ranger
- Engine Type
- 3.0 V6
- 2WD / 4WD
- 4WD
Howdy y'all, I have a 94 Ranger, 3.0, standard, 4wd. Transmission was rebuilt a few thousand miles ago (May of last year).
The other night, on my way home from work, I put it in third gear. About 5-7 seconds after accelerating, I heard and felt a loud *THUNK* and it kept on moving. I slowed down and shifted into 3rd again and sure enough, after a few seconds, *THUNK*, albeit with less force. This did not happen in any of the other gears.
Oddly enough, the *THUNK* did not happen again in the days following, despite my efforts to replicate it. I thought it must've just been a fluke, but today it happened again, once again in 3rd gear. Yet again, however, it stopped doing it for the rest of the trip and I couldn't replicate it.
Some things to note:
-The first time this happened, I began to hear a whining sound that rose and fell with the RPM, even with the trans in neutral and the clutch disengaged (I opened the observation port and had my friend press the pedal a few times with the engine running to verify that it was not the throw-out bearing). This sound has been determined to be the idler pulley, though I'm not sure how/if this could be related to the *THUNK*, as it has only happened in 3rd gear.
- The ring gear in my diff is missing a tooth, but this has never caused me any problems in my almost 4 years of ownership.
- The weather here has gotten pretty darn cold, dipping into the single digits. I have full-synthetic 5w30 inside my transmission, so I try to baby it for the first few miles while the trans warms up.
- The transmission was rebuilt last May, and only a few thousand miles have been put on it since may (the whole truck is sitting pretty at about 326k). If there were something broken in there, wouldn't the *THUNK* be happening more regularly and be easier to replicate?
- The u-joints are pretty firm, but there is some slight play in the slip yoke. But I'm not entirely sure if that's the cause of the issue because the sound is happening well after the power has gone from the engine to the ground. If that were the issue, wouldn't I be hearing it right at the beginning?
Any advice would be appreciated, I'm honestly kinda stumped.
