OBD-ii codes for Flex-Fuel (composition) Sensor output?
fixizin
FoMoCo is forcing me to buy a 'yota
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
I know there's a xx706 code if the ECM reports a malfunction with the infamously-eh-spen$ive FlexFuel sensor, BUT... is there a real-time output, similar to the fuel-trims, etc, that basically tells you what % ethanol it's sensing? :icon_confused:
fixizin
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
The answer, apparently, is nay whinnie, no. Bummer.
pjtoledo
2,992
Toledo Ohio
Fords
3.0 2.3
Forscan, a diagnostic tool, gives you the percentage of alcohol in the fuel.
fixizin
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
Forscan... NOT gonna say what it ALMOST sounds like... but will check it out!
(Drill Sergeant: "Platoon! Fall out!... short-arm inspection in 5 minutes!...") ;)
