NP 205 Speedometer worm gear
Elutheros
129
Central Texas
My speedo quit and I'm trying to diagnose the problem. Replacing the speedometer cable had no effect, so I pulled the VSS out of the T/c and found that the worm gear will spin using my finger through the hole for the VSS. Seems like that should not happen. Anybody ever encounter this?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i have split them before....is it a white 7 or 8 blade?
usually the driven gear gets worn in the center.
Elutheros
129
Central Texas
I can't see which color or number of blades due to the position of the hole. I'll have to get a mirror and take a look. I'm using a white drive gear on the cable end and with my 3.73 gears and 33" tires it's more accurate than my vehicles with electronic speedos.
