No Replacement For Displacement?
Broosedamoose
115
South East Massachusettes
4.0L SOHC
31 x 10.5
Coming in second just makes you the first loser!
So, I'm not looking to start an argument here! I'm just looking for the logic behind this and if it still applies in todays engines. My 4.0L is said to make 207 Hp. and 238 Lbs. of torque. But, my wife's Highlander has a 3.5L and it makes 270 Hp. and 248 Lbs. of torque! So, less displacement and more Hp. Even with Headers, a cat back exhaust and a custom tune my truck still makes nowhere near that much Hp. So how can this be true?
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,515
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Technology...
Things like variable cam timing... cylinder head flow rates... compression ratios... volumetric efficiency.
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Stroke & compression? Cam profile difference?
ericbphoto
Overlander in development
16,694
Wellford, SC
6"
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Think that's baffling, a ford 7.5L (460) V8 only made 245 horse in it's last production year....
Technology makes things go vroom better.
19Walt93
4,484
Canaan,NH
351
3"
235/55R16
A 3.5 EcoBoost makes over 400 hp in some tunes, my son's 2.7 EcoBoost Fusion is 325 hp, my 2.0 EcoBoost Escape is 240-280( I forget which). Note that the torque is only 10 lb/ft higher? If the torque peak is higher it would feel doggy in a heavy vehicle. Talking about horsepower is one thing, what you feel accelerating is torque.
17,944
SW Iowa
I read somewhere that the stock heads on a 460 flowed about right for a 302...
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
They had to get that old dinosaur to pass a smog test somehow...
17,944
SW Iowa
Ford heads were a weakness for a long time.
If 460 heads were about ideal for a 302 where does that leave the 302?
But they were also trying to squeeze all the torque they could out of the for truck applications which is usually counter to getting max power.
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
What year is the highlander, and what year is your truck?
Right off the bat I see that the yotas motor is 4 valves per cylinder, the ranger only 2.
The ranger motor could only be 9:1 CR and the yota depending on year could apparently be as high as 11.8:1. Those two things alone would make a good difference.
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Racing Stripes!
17,944
SW Iowa
Cosworth DOHC 24v 2.9 heads get the 4.0 in the ballpark.
In my rather uneducated opinion it is a shame Ford didn't do that instead of the 4.0 SOHC.
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
the saying still holds true if you consider how modern engines displace more air due to design improvements.
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
It's a shame ford didn't give us a lot of what they gave those limey shmucks back in the day.
17,944
SW Iowa
Cosworth isn't really Ford though.
