lost86broncoii
- Jun 4, 2009
- 1
- Baldwinsville, NY
1986
199
- Ford
- Engine Size
- 2.9,2.9,4.0
Hey guys, I picked up an 86 ranger last weekend for mygirlfriend, so I can get my 86 Bii back from her. She wanted a ranger, I just couldn't argue with that. Any way, we picked up an 86 extend cap, 4x4, auto(tm tc hubs door windows locks), and none of the automatic stuff still work except the transmission thankfully lol. But changing that stuff for manual is not my issue with it, I plan to swap in lock outs, manual transfercase or shifter, and a M50D-R1. But right now the truck is having problems accelerating, very light throttle and its alright and I am talking like barely anything on the pedal, any more it starts to stumble a bit like it wants to go but is being held back. At first it was just stalling out when I came to hard stops and was a little rough on the idle but would still accelerate, only felt a shudder every now and then. Under the hood and I saw the fuel pressure regulator was rusted, and had a spare for my Bii I knew was good so I threw that and a used coil onto it, also a map sensor and a new TFI module that was going to go onto the bronco, also the fuel pump inertia switch is bad on the truck, looks like it shorted out at some point(dark marks on wiring to it), currently have it jumped with a short length of wire at the pigtail. After that the truck stopped dying at stops but now doesn't want to accelerate... I haven't changed the fuel filter yet, and air filter is good. I will do the 02 sensor this weekend when I get my paycheck. Any other thoughts on the lack of power? At idle it sounds fine, or just reving it up in neutral, or very very light loads starting out, but try to give it some gas it starts choking...
I did have the Oil Pressure warning light come on a few times, but the truck seems to have oil pressure, sounds fine no ticking or other valve train noise. That still kinda worried me a bit, I know the 2.9 had some oil pressure problems and getting oil to the heads? What can I do to look into this problem or could it just be a faulty switch? Would some cheaper aftermarket gauges be worth it/useful?
The battery light also came on a few times during driving it around while it was stumbling(the battery is brand new and charged), truck seems to have a little grey or white smoke coming from it, but it was really cold today and hard to tell for sure. Thanks for any help with any of these problems.
