Well I don't believe that any rangers ever came with or had the option of factory heated seats so you are going to be doing your own fabbing. It isn't too hard. What you need is 2 relays and fusable links, A couple switchs and wire (preferably different colors for ease.)
What you do to hook up the relays would be to run power wires from the heated seats power wire and find a ground in the cab for the ground side. Run the wires to the relay (pin 87, one per relay). Then next is to hook up the switchs so that they only come on when the ignition is on.
Find a place for your switches that you like, 2 switches (one for each side, unless you just want them both to come on with one switch) Then start at the relays, run a wire from each relay (pin 86) to the accessory out pin on the switches then on the power in you need a source of power thats only on when the ignition (or even accessory too) Like the radio ignition power wire, Its red on aftermarket HU harnesses. It takes basically no power so don't worry and if they burn out it won't pop your radio (thats what fuses are for). I would use one of these:
and run one wire to each switch. And then Run grounds from (pin 85) and the switches if you opted for light up switches. Then All you have to do is run Fusable links or fused wires directly from the battery to the relays (pin 30) I think a 20 amp fuse would be fine maybe bigger...?
And there you have heated seats that will come on at the flick of a switch and only come on when the key is in ignition or accessory.
For reference you can always just go to this page... I just thought I would discribe it.
http://www.therangerstation.com/tech_library/relays.html
Its basically the same but you just use 2 single relays and hook the accessory power to an ignition on only wire.
Edit: I can get you a pic of a KC light harness which is basically what you are looking to do.
