Erff Erffalotte
- Dec 30, 2022
- Reaction score
- 8
- Location
- N. California
- Make / Model
- Ford Ranger
- Automatic
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Actually after looking closer it looks like someone used a black wire for the postitive. I think i spy a "+" there.If that cable is on the battery Positive terminal, don't ground the short take-off wire.
That's not an original cable. Being black, it's likely a replacement battery Negative grounding cable, used to replace the original Positive cable (which would have been red). As @rusty ol ranger points out, the battery Negative grounding cable would have a take-off wire to connect to and ground the body.
It looks like the yellow butt connector was never crimped a second time, so probably nothing was ever connected to it in the first place. It's just a case of a "close enough" aftermarket ground or universal cable used to replace a failed original battery Positive cable.
Just leave it be, or tape it up to neaten things. The factory point for constant Positive wire connections don't connect at the battery anyway- they are at the starter relay (solenoid).
