My 44 Knuckle Swap 35/44 Hybrid
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
:headbang: Thats how Ford should have built it from the beginning. Looks good.
97TrailRigDD
August 2011 OTOTM
Evansville , IN.
4.0 OHV
Yep , it is a much better design .
Hubs did not need to be pressed into the new rotors , but the studs needed to be pressed into the hubs and that holds the rotor in place .
alwaysFlOoReD
5,153
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Looking good! For those that don't have a press, could you draw the stud with a nut and lots of lube....like neversieze?
Richard
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Or put the piece needing pressing under the frame of a truck and using a bottle jack press it in/out that way...
SVT
97TrailRigDD
August 2011 OTOTM
Evansville , IN.
4.0 OHV
Got some bling bling .
dirtcowboy
5
NW Montana
FORD
2.9, 4.6, 4.0, 6.8, 5.0x4
Great stuff, question, how much wider is the TTB 44 hubs and such than the dana 35 parts? I've spent all winter collecting parts and as soon as it warms up I'm going this route as well.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Richard
I always just use a hammer and drift to put them in at work. Press is too slow.
97TrailRigDD
August 2011 OTOTM
Evansville , IN.
4.0 OHV
I think it is the same width . I'll get a measurement tomorrow .
Wheels are leaning out 3 degrees . It has 0 degree bushings in it now , I'll try to get some new bushings tomorrow .
7
murphy north carolina
2.8 v6
is that on the edge for tire size? if i was to do this and run 35s i should be ok.
97TrailRigDD
August 2011 OTOTM
Evansville , IN.
4.0 OHV
I don't know really . But I have new 35's on it locked front and back , so I'll let you know . The 1.5" spacers on the front should be a good test for the wheel bearings .
86 slo-vo
02/2011 OTOTM Winner
36
owensboro, KY
Those hubs look good, do I get a finders fee on those? :thefinger:
