wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
- Aug 11, 2007
- 21
- Age
- 37
- Edmonton Alberta
So, I ran across a ranger in my buddies towing yard and found it was going for scrap...specs are as follow's:
90' excab 4wd
2.9L M5OD
D35/8.8
Now, I was after the Tcase so I took a quick peak under it and there she be! Fixed yokes front and rear and an M5OD shifter, in my mind all is good.....
I flipped the truck over with a loader (way easier then laying in snow in -35*C), sawzalled the driveshafts and pulled the case. Once I brought it back to the shop and pulled my 1354E I began swapping over speedo output, vents, driveshaft leftovers back onto the E case etc. I benched it over my head under the truck and slipped, dropped the case and proceeded to atleast bruise a rib or two I saw 4 numbers that began to make me wonder.....
The case that just knocked the wind out of me, say's 1350 in a series of number in the input housing.....making sure I'm not seeing things or its a random number I check my E case and sure as shit it says 1354.....I figure what the hell, the driveshafts bolt up, the shifter bolts up I'm gonna use it anyways but here's my question....
-it's NOT a highrider truck
-It DOES have fixed yokes
Was this case built from a 1354/1350 pile of parts as a replacement? It's got a bead of RTV on the split so I know it's been apart but I thought for sure that 90' would have a 1354 or the 1350 in that year would have had a slip yoke? Also, should I be worried about it's strength in relation to the 1354 as it's a 5000lb truck on 35's locked front and rear?
-andrew
90' excab 4wd
2.9L M5OD
D35/8.8
-andrew
