Missing harmonic balancer bolt thread pitch and length?
rangeron33s
missouri
2.9
Title pretty much says it. Bought an 88 with the 2.9 and it's missing the damn main bolt on the harmonic balancer. Dont know how unsafe it is to run without it but I feel like I should probably get one asap. Trying to look everywhere and all I can find is ones for the v8s. But I dont know if theyll cross over. So if anyone knows or has one laying around that they could measure up for me thatd be awsome
BrutalPanda
5
Personally I wouldn't run it without it at all, but that's me. I'm swapping my balancer tommorow, so I will measure it for you if you don't get your answer by then
Sent from my Pixel 2 using Tapatalk
rangeron33s
missouri
2.9
Well I figured out the thread pitch but still need the length. It's a m12x1.5 if anyone is ever interested in that. It's the exact same as the head bolt. Unfortunately unless the bolt has about 6 turns in it, then the previous owner snapped the bolt off in there. So I will still need the length of possible, length of threads and length of the shaft itself. Thanks in advance
Paulos
210
North Carolina
1987 STX
I just check my parts and came up with 12 x 1.5 x 75, hex head, no shank, "KAMAX 110" on the head. When measuring the crank and the vibration dampener, the bolt will screw into the crank about 1-1/8" (the dampener slides on 1-1/2" of the crank, minus the timing gear). There was a flat washer in the same zip-lock bag that would not fit anything else in the bag, so I'm assuming it goes with the bolt - 24mm OD x 3mm thick. I hope that helps.
