M5OD clutch/pilot replacement, vibration in 4th and 5th gears
Pony Boy
I just replaced my clutch in my 2wd '88 2.3 Ranger, M5OD trans. While in there I realized the crank had NO pilot bearing installed! I never noticed much from a lack of one, I've owned the truck for 10 years, but it doesn't get alot of miles. It was buzzy, but I assumed that was the nature of the buzzy 2.3, and the solid rubber motor mounts I have.
I installed a new pilot bearing along with the clutch, and while the truck is smoother all around, now I have a very serious vibration in 4th and 5th gears only, at around 2000 rpm's in either gear. The vibrations are enough to shake the floor of the whole truck, I can really feel it through my seat, and it only happens under power. Coasting it doesn't do it, clutch in it doesn't do it. I can drive at the 2,000 rpm area, get the vibration, and immediately put the clutch in or let off the throttle, and it goes away. As soon as I give it a little throttle again, in gear, the vibration comes back. It goes away above 2,000 rpm, and only happens in 4th and 5th gears.
I'm wondering if I damaged bearings or gears from running for so long with no pilot bearing. I did notice the input shaft seal was leaking when I removed the tranny, I'd assume from the pilot bearing not supporting the input shaft and the shaft was able to move around and damage the seal. What should I be looking into? There's no whining associated with the vibration, like I'd expect with a bad bearing. I'd liken the vibrations to when you're bogging a big diesel in a gear too high. However, I can run at 2,000 rpm's and lower in gears 1-3 and I have no vibrations at all.
gearfather
18
twin cities mn
it is not very common for a manual trans to ""suddenly" vibrate, make sure that the bolts are tight. also, is there alignment dowls between the motor and trans?
TexasDuck66
July Truck of The Month
25th Anniversary Merch
