Lunchbox locker clearance
Bryan B
Wasilla, AK
Hi guys. I'm looking to install a lunchbox locker in my front differential on my 99 Ranger, it's a Lokka locker. I had to remove the side gear thrust washer to get the recommended clearance from the center pin. That ended up making my center gap between the locker .011 wider than what is called out. That would mean I need about a .006 washer on either side gear.
So a couple of questions, do you think the .011 over spec matters? Can I find a .006 washer?
Thanks for any advice.
00t444e
217
Southern OH
Ranger ext cab
How is it with both of them in?
alwaysFlOoReD
5,111
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I'm not 100% sure of your question. I don't have the washers to install, that is why my gap is a little wider than spec.
This is a WAG. Wild Ass Guess, on my part. I have never looked at one. Going from the pic I would say that there will be slightly less spring tension pushing the lockers together, so they will disengage easier. No idea if that hurts or not.
00t444e
217
Southern OH
Ranger ext cab
What do you mean you don't have the washers? You use the ones that were behind the side gears.
Bryan B
Wasilla, AK
Sorry, I have the existing washers, I just don't have the washers that I need to get to the recommended clearance.
If I use the existing side gear washers, I'm nearly touching the cross pin, which is to close, and the final gap between the locker is way to small, I believe it was somewhere around .145 when minimum it's supposed to be .189.
00t444e
217
Southern OH
Ranger ext cab
Try it with the existing washers.
ericbphoto
Overlander in development
16,620
Wellford, SC
3.0L
6"
A local machine shop with a surface grinder can make your existing washers thinner or even shave just a little bit off the sides of the locker that contacts the washers. Must take off even amounts from both sides.
superj
2,587
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
maybe these is a master spacer kit available from jegs or summit for what you are doing? or maybe you can get just the size washers you are looking for from them?
we have a machine at work for cutting shims and spacers to the thickness we need for the gearboxes we build but i know most shops couldn't afford that kind of stuff so they would have to buy kits or single sets from somewhere
Bryan B
Wasilla, AK
Thanks for the replay's. I've talked to a local shop here that can hopefully cut me the washers I need. If they decided they can't do it then maybe I will see about grinding down the existing.
I've never looked into something like this and as thin as I need the washers I'm not sure what is realistic.
BlackBII
Ranger Custom
Truck of Month
982
UT
Bryan B
Wasilla, AK
fastpakr
2,834
Roanoke, VA
Bryan B
Wasilla, AK
Does anyone have any experience that would say having it .011 put of tolerance would matter? That's what it is out with no washers in at all.
ericbphoto
16,620
Wellford, SC
3.0L
6"
It will work. But isn't ideal. It has to do with the way the center pin pushes the side pieces apart. It would be best to get it as close as possible.
With not enough clearance, the locker will mot separate and unlock when you need it to. With too much vlearance, it will be sloppy and may promote premature wear of the cross pin. If seriously in doubt, ask the manufacturer. They should be able to explain why that clearance range is required or recommended.
