Low Idle in 94' Explorer
YooperSteeze
Da UP, eh?
5.0/4.0/4.0
I have a 94' Explorer, 4.0 OHV, and its very tired with either 196k or 296k. Took it on a wheelin trip to my buddy's camp this weekend, on the trail there I developed a low, 500 rpm, and very rough idle, but as soon as I got on the throttle she cleared right up. It got slowly rougher and rougher as the weekend went on. Today I had to get some gas in BFE to make it home, and of course they were out of regular so I was forced to pay $4.69 a gallon for premium. When I went to pull out of the station, I turned the key, it started but died out instantly. Tried again and got it to stay running by revving it to 2k and I high tailed it out of there. I let the rpms drop to slow down for a corner and it instantly died out, went to neutral started again and just kept her to the wood the rest of the 45 minute journey home. Got home, cleaned the MAF sensor and gave it a bottle of seafoam and it ran, but only idles at 5-600, even after fresh gas. However it is idling a lot smoother than it did before when it was that low. The check engine light is on, has been since I got the vehicle, last time I checked the only relevant code was clogged egr. I talked to one of my buddies and he thought it might be the idle air valve but we didn't get a chance to look. So I'm asking for any help or opinions. I'm not the best with engine work/diagnosis. Thanks in advance!
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
It appears that you have some diagnosing ahead of you. Sparkplugs? Wires? Fuel pressure? Fuel filter? Ever done any of these?
YooperSteeze
Da UP, eh?
5.0/4.0/4.0
Haven't done those on this. Added a few fuel filters on my ranger, been around and paid attention when my buddy has checked plugs on our race truck. Beyond that nothing else you've mentioned.
daniel3507
74
NE Oklahoma
2.3 EcoBoost
Start basic first. Change fuel filter, check air filter, PVC, make sure its got spark. I know you said you cleaned the MAF but I had to replace mine after cleaning. Ran better.but not great after cleaning so don't count that out 100%.
You may just want to replace the IAC rather than clean it. They are hard to really get clean
Sent from the think n' stink.
YooperSteeze
Da UP, eh?
5.0/4.0/4.0
I picked up a fuel filter, tossing that in after class today. Hopefully that clears it up. Already checked the air filter/box, thats all good.
YooperSteeze
Da UP, eh?
5.0/4.0/4.0
Finally got my fuel filter in, after getting blasted in the face with gas... all part of learning to get out of the way hahah. Anyway, that didn't clear up my low idle but it seems my mileage has gotten a little better. What should be next on my list to check? Cleaned MAF, checked air filter/box, changed fuel filter. Thinking of checking back pressure, my buddy thinks I might have blown my cat after running it for awhile and it getting dunked in nice cold water when I was out wheeling. It has spark, because it runs. Still daily driving it.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
IAC motor passage could have carbon it in. Clean it with carb cleaner. Is it sluggish when you drive it? I don't know if the cat would be bad cause you sunk it in some water.
YooperSteeze
Da UP, eh?
5.0/4.0/4.0
Yeah the cat thing sounds to me like some crazy theory but my buddy has seen it happen. Yeah its sluggish, it has been since I bought it though. I need to take some time and figure this out. Thanks to everyone who has helped so far.
aspevacek
4
Harrisburg PA
4.0 OHV
Look into cleanign your IAC and look at the "Blocked " EGR port. EGR can cause all kindas of strange idle issues.
YooperSteeze
Da UP, eh?
5.0/4.0/4.0
Yeah those are top of the list now, just need to find the time... Damn college. Never listen to your adviser. Mine has me taking 18 credits in my first semester.
YooperSteeze
Da UP, eh?
5.0/4.0/4.0
My buddy hooked me up with an IAC off a 4.9 that he found at work, I tossed it on the other night and now she runs and idles beautifully!
