aball4620
- May 13, 2020
- 3
- Seattle
- Ford Ranger
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
My '88 2.9 with dual tanks is still giving me issues after replacing the head gasket. It starts fine, and tries to idle but surges constantly. The rpm's won't climb above about 1900-2000 with the throttle wide open, and it constantly stumbles while idling and until it is warmed up will periodically stall. I'd been dealing with some quickly dissipating white smoke out of the tail pipe for the last couple years as well as horrendous gas mileage (about 7-8 mpg). This has/ had the crack prone heads so I replaced the heads with new clearwater heads and all the gaskets. Will limp out of the uphill driveway, but is not drive-able.
The fuel system was totally FUBARed by the previous owner and the most recent discovered was a kink in the feed line between the tank selector and the reservoir, as well as some sort of failure/ clog in the return line valve inside the tank selector, which was causing pretty high back pressure. It currently has a new pump and fuel relay and a new harness and does turn on for the 2 seconds each time the key is turned. But, pressure will not climb above 36 psi no matter how many times I cycle the key. I understand that pump should go to 50-60 no problem. The FPR is new and dry. I hear some sort of gurgle coming from what sounds like the reservoir once it hits 36 psi. This happens on BOTH tanks - meaning both lift pumps. Pressure bleeds to about 32-33 after an hour and down to about 25 after 24 hours. Codes are inconsistent, meaning sometimes they show up and sometimes they don't. Typically they involve the TPS - which is new and the circuit has been checked. Injectors are new and tested for leaks - they look fine. The truck acts like it is starving - possibly both low pressure pumps have failed and the high pressure pump is exhausting the reservoir? I'm at a loss. Anything standing out?
