Low beams suck but hi beams are fine
16
Maud, Texas
Ford Bronco II
Howdy everyone
On my 90 Bronco II, I replaced the factory headlight housings with some new ones about a year ago. It made a vast difference in the light output. However, the low beams still suck. They light doesn't really travel that far out on to the road like the sealed beams in my 87 does. High beams work fine, plenty of light I suppose. If anyone has any tips on how to fix this I would greatly appreciate it.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,707
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
How's the head light aim? They might need adjusting. I forget what the specs are but there is quite a few things on the internet about what the right distance to a wall is. What the height should be. And where they should be pointing in relation to the vehicle. Granted, that's the redneck method but it has served me well in the past.
16
Maud, Texas
Ford Bronco II
to be completely honest, i never aligned them. they seemed in line just fine to me, but maybe i was wrong. I'm sure thats probably it now that you say that.
sgtsandman
Ham Radio Operator
12,707
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Only a possibility. Some vehicles just suck when it comes to light distribution, sealed beams or not.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,509
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Looking at the picture... they do suck!
I don't believe for a minute that all these cheap headlamp housing are created equal. Did you buy the cheapest ones on the internet?
I think some of it can be corrected with aligning the headlamps. They appear to be aimed to low to the ground to me. But as poor as it looks in your picture... it's probably worth some time researching the internet and maybe someone with experience with these Gen 2's will chime in and shed some LIGHT on this for you... no pun intended.
16
Maud, Texas
Ford Bronco II
Thanks for the reply Uncle Gump. They weren't the cheapest on eBay but they weren't the most expensive either. I'll align them when I get the chance but I don't think it'll help all that much but I'm sure it'll make an improvement.
I'm wondering if converting to projectors with hids would make a difference. I had some led bulbs but they were worse than the halogens, and they were just in the reflectors.
gaz
671
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
There are 2 screws to align your headlamps, one @ 12:00 the other @ 09:00.
Do it on a level surface approximately 25 ' from a wall.
racsan
4,492
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
sometimes it can be that you get used to a new(er) vehicle with extremely good lighting then when you go back to a older ride they seem awful. I remember when halogen lights first came out, suddenly the sealed beams in dads 74 F250 seemed really weak. Before you knew anything else they werent that bad. I put a small 7” off road light bar on my ranger so that when I was coming home at 2 am I could see better.
16
Maud, Texas
Ford Bronco II
rascan, would you mind posting a pic of your truck with it on there? and also, where did you buy it?
