Lifter problem
SWE_lollo03
Sweden
Hello, I have been swaping transmission in my ranger so it's been sitting for arround three months and now when i started it up allmost all the lifters make noice and one makes really load noice is there anyway to fix that?
Paulos
210
North Carolina
1987 STX
If you have already confirmed that you have oil pressure, you might want to check out the first thread in the 2.9L forum. If it was working fine before you started work on the trans I would try the Seafoam treatment. If the oil hasn't been changed in a while you might consider doing that also before you put the Seafoam in the crank case. It won't immediately stop the noise, but it will help (it did with my 2.9).
gaz
656
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
SWE_lollo,
Welcome 🙂
I would verify oil pressure when running but look at the oil level and how it looks on the stick 1st.
Next area I would suspect is under the valve covers. So if the oil pressure is good and the oil on the stick looks how you expect, then I would pop the valve covers and remove the rocker shafts, expecting them to be caked with SLUDGE.
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
after the engine warms up and oil is flowing does the noise get quieter? if so, i wouldn't worry too much about it... and as far as seafoam goes ... do it at your own discretion.
